Grease Pencil: Task Force
The Grease Pencil 3 project is well on its way, but there are still many tasks left to do. This is a call to the Blender community to help out and get Grease Pencil 3 out of experimental mode!
What is needed?
Development and testing. The main priority is to get feature parity with the current Grease Pencil.
In Edit Mode, we are still missing most of the operators. There is a list of tasks targeted towards newcomers to help port these operators.
How to help?
The Overview Task has a brief description on how to get started as a developer as well as a list of tasks to work on.
If you are not a developer, you are still welcome to test Grease Pencil 3.
  1. Grab the latest alpha build of Blender 4.1
  2. Enable it from the preferences under Experimental (once Developers Extra is enabled in “Interface”).
Please note that the 2D Animation template doesn’t work with Grease Pencil 3, and any tests should be done on new files, since older Grease Pencil objects will not get converted to the new system yet.
Enable Grease Pencil 3 from the Preferences editor, under Experimental (once Developers Extra is enabled in Interface).
If you find a crash or a bug, you can share it in the Grease Pencil 3 Feedback thread on Dev Talk.
Grease Pencil Work Board
Thank you!
If you are interested in contributing, drop by the #grease-pencil-module room in Blender Chat and get connected!
Support the Future of Blender
Donate to Blender by joining the Development Fund to support the Blender Foundation’s work on core development, maintenance, and new releases.
NPR Project
Projects Update – Q2/2025
Frame Node Improvements
Declarative Systems in Geometry Nodes
4 comments
  1. Nice of you to thank those who contributed to the #grease-pencil-module room in Blender Chat, it should be appreciated as well
    Right-Click Select ideas for Blender as a contribution.
  2. Do you have a similar “Community Tasks” for Geometry Nodes with a list of new nodes that need to be added?
    • i would say first and foremost, for Geometry Nodes blender need all basic polygonal modeling operators, which polygonal modeling people are using everyday, so far we have only ‘Extrude’ node
      There is no ‘Bevel’, ‘Loop Cut’, ‘Knife’, ‘Bisect’, ‘Twist/Revolve/Lathe’ and so on
    • The Geometry Nodes integration was mostly done by the Geometry Nodes team. The first milestone (only porting existing nodes) is pretty much completed and we don’t plan to add more nodes anytime soon. The focus is on getting existing features in the current Grease Pencil working in Grease Pencil 3.
In order to prevent spam, comments are closed 7 days after the post is published.
Feel free to continue the conversation on the forums.
