Gitea Diaries: Part 2
About three weeks in, it was time for another update on just where we are, where we’re going, what’s happened, etc.
Howerver there’s a few things that got in between; a short vacation as well as a bit of bad luck with Covid19; but everything’s alive and kicking. Thank god for online software development.
On the 10th of August, I recorded a set of short videos just in between getting better from Covid and before having to leave for a short trip of two weeks.
It sadly too until today for me to get to posting them publically.
Below is a playlist of 10 videos that give an overview on where we stood on the 10th of August.
Picking up from where we left off then, I am happy to report that since then there’s been some progress on some of the mentioned areas already.
Baseless patches
Specifically, the issue discussed in part 8 (‘Specific issues with baseless patches’) has seen some approaches tested with promising results that allow us to get them into Gitea’s data-model properly and neatly.
The upshot is that we’re iterating through the data we get from Phabricator on every pull-request it has, checking for any info it hands us. If we have a commit-hash for each patch-revision that’s part of the pullrequest/review , then we obviously have no real issues and can get the data properly into Gitea.
There are however pull-requests where there’s only one revision (typically the last) that has an associated commit-hash associated with it. In fact, there’s also quite a few that have NO commit-hash associated whatsoever. These are the troublesome ones, but it’d seem that using a git-bisect approach allows us to retro-actively come up with a *valid* (read: not necessarily correct) commit-hash that the patch applies cleanly to.
It is likely we’ll include some kind of attribute/comment to these to indicate they were ‘best match’ retrofits and not original data.
The issue of what to do with these kinds of ‘baseless patches’ was quite a complicating topic, so it’s nice to see that the first code-experiments of our suggested approach seem to be working out.
Next update
A next update is expected to land somewhere at the end of this week or the beginning of the next.
NPR Project
Projects Update – Q2/2025
Frame Node Improvements
Declarative Systems in Geometry Nodes
2 comments
  1. Thanks for the update, listened to these while working and find it interesting to know whats going on behind the scenes.
    The issue of repositories and de-duplication is quite interesting, it’s unfortunate file-system level de-duplication isn’t a good long term solution (as you mention the underlying files diverge).
  2. In Part 6 of your playlist, you asked for input, so here’s mine:
    Yes, that sounds like a useful feature; but instead of adding an offset, you could encode them as odd/even: Task `n` would map to `2*n` in gitea, Differential `n` would map to `2*n+1`. The reverse mapping from gitea to phabricator is just divide by 2 and the remainder gives which type. If you have `k` types of data, multiply by `k` instead of 2.
    A big thanks to you and all the other folks at Blender for all you do.
In order to prevent spam, comments are closed 7 days after the post is published.
Feel free to continue the conversation on the forums.
