Improving node group interface editing
General remarks on node groups
Node groups will hopefully get more attractive and useful in the future. A new asset manager is being worked on, which i hope will make it much easier to efficiently share and re-use complex node group setups too, in addition to objects, rigs, materials and the like. This may not be very important for compositing work, my impression is that in that domain artists usually “stack up” effects one after the other without reusing specific setups a lot. However, in the case of shader nodes (Cycles) and the upcoming particle nodes as well as future modifier nodes this scenario is much more likely. There are basically two different ways to make use of node groups (apart from simply saving layout space):
  1. Build up complex effects out of small elementary parts
    Examples:
    – Generic diffuse/specular/environment shader from different bsdf nodes, to be used as a “classic” material
    – Particle emitters from basic components, such as create new particles -> distribute on mesh surface -> initialize velocity from normals, etc. Combine these in a single node group and you have a complete particle emitter asset.
    – Procedural objects with modifier nodes, e.g. a “window” asset from simple base shapes and user settings like dimensions, number of panes, frame thickness, and of course different material slots for all the parts
    The advantage of generating such complex effects from simple components instead of adding them as a new node type is customization: You can take an existing shader/particle effect/object, make a copy of it and then tweak any internal part to make a new one. All this can be done by artists or TDs, without having to write C code and either use their own Blender builds or get a patch accepted into trunk.
  2. Interface reduction
    Often a node can be quite cumbersome to set up, especially if it is a complex node group with lots of different user options. Reducing the interface of such a node or node tree is a good way to create a usable tool by only exposing those settings that artists need frequent access to. Any setting that is not exposed will just use a default constant value internally.
Problems with editing node groups
The current paradigm of “opening” node groups in a single top-level node tree has a couple of flaws:
1. Only a single level of node group depth
You can actually add node groups inside other node groups by now, but you can not actually edit them on that deeper level. The only way to work around this is by adding a second instance of that node group at the top level and edit it there.
2. Only a single node group can be edited at a time
This design is supposed to mimick the edit mode feature used for objects in the 3D view. However, the edit mode paradigm does not really apply to them. While objects are composed of different internal elements (vertices, edges, faces) and do not contain other objects in turn, node groups are recursive by nature (a node containing other nodes).
Removing this limitation is difficult: On the design level it would mean a lot of graphical overhead to edit groups inside other groups (inside other groups etc.). Each group currently has a list of interface sockets, taking up space. Also opening a group node usually leads to overlapping with nodes in the background, so the visual outcome is ugly and confusing. Furthermore the simple “tab-tab” switching between open/closed node group would not work any longer, since it can mean to open an internal node group as well as closing the parent group.
On a technical code level this change would have big implications on virtually every single node operator, since these work by detecting the active node tree and the active/selected nodes from the context. If any of the open group nodes (which all have their internal node tree) can be eligible for editing then each operator must be told explicitly which tree/nodes to work on.
3. Input/Output columns in display
Currently a node group has a number of sockets on the left and right displayed in columns, which translate to sockets on all instances (group nodes) of that tree. These “tree sockets” (as opposed to node sockets) are connected to the internal nodes.
Complex Cycles node tree for a snowy mountain shader
The problem with this is that the tree sockets placement is completely automatic, unlike other nodes which can be placed freely. What”s more, the overall size of the node group editing windows (and therefore the tree socket columns) changes when moving nodes around (bounding box).
Moving nodes around also moves the tree sockets
With a lot of group sockets you end up with lots of long connections, especially when some input is used at the far right of the group tree (and vice versa for outputs). Add to this the new “drop on link” operator that automatically inserts nodes on links and your node group editing becomes very hard to control and frequently does unintended things.
Stupid long links getting in the way, i didn't want to insert that there
Just for the sake of completeness: The shader node tree above uses a combination of Z height limit and normal angle to Z axis in order to create masks for a snow-capped mountain. The details are not really important here, it”s just one of the more complex node trees i had lying around that is suited to demonstrating node group features. This is what the result looks like:
Solutions
Make a usable “frame” node
There is a new node type called “Frame” in the Layout category that provides functionality expected from node groups (the naming should be changed as well, one suggestion was “Tray”). The current implementation is still experimental, but with a little bit of work it can be a great feature.
The basic idea is to use this as a kind of local grouping helper. Any node (including other “frame” nodes, groups, etc.) can be attached to it, much like object”s parent/child attachment. Moving a frame node also moves all attached nodes. They can be linked to nodes outside the frame. Hierarchies of frame nodes can be created as well.
Unlike “real” node groups these frames can not be instantiated (shared), but they could allow simple duplication of all attached nodes. Since this is a very common use case for group nodes they seem to be a good replacement for local grouping of nodes.
Here”s a list of proposed additional features:
  1. Clear indication of attachment (currently not visible)
  2. Beside explicit operators for attaching/detaching nodes to frames: Moving nodes outside of a frame detaches them.
  3. Moving nodes into a frame while pressing a modifier key attaches them to the frame (currently always attaches automatically).
  4. Frames can be locked, i.e. no attached nodes can be moved, all buttons are inaccessible, no linking, etc. This way the frame can be handled as a fixed, local group and makes editing easier.
  5. Frames can be collapsed, to free space in the layout. This has some design challenges though, like how to deal with links to/from the attached nodes.
  6. Standard operators for duplication and deleting work both for a selected frame node alone as well as the frame plus all attached nodes (using a modifier key)
  7. New operator for “make frame around nodes”, similar to current “make group from selected nodes”. Ungrouping simply means deleting the frame node (see above).
Not included here are all sorts of UI display improvements, such as easier resizeable borders, custom color schemes and so on.
Frame node hierarchy, active node highlights parent frames
Edit node groups as separate trees
Reusable, standalone node groups would be edited just like any standard node tree would be. When “opening” a node group the editor display will switch to the internal node tree, instead of pretending to display a specific instance of that group in its parent tree (which is in fact just the shared node tree). This way the editing of nested node groups works in a consistent way across all possible levels.
No more nodetree/edittree distinction in the node space struct is required, there”s just a single active nodetree. The node editor window can keep a history of node paths in order to allow a web-browser-like behavior:
  • Opening a node group pushes a node path onto the history stack, before switching the node tree over to the group internals. (“Follow a link” in web browsing terms)
  • Closing the node group means popping a node path from the history and go back to the previous tree.
This behavior may not be quite as immediate as the tab-tab edit mode currently possible, but it seems that this a tradeoff between flexibility and simplicity. For simple grouping the frame node type described above would be used instead. Node groups on the other hand will become the choice for long-term reusable node assets.
It may be a good idea to actually implement these nodes as a completely new node type “Asset”, instead of remodeling the existing Group node type. This way the usability can be tested and if successful the Group node type can be removed at some later date.
Detach interface sockets from columns
Instead add an actual node for each socket in the group tree interface. These would be specialized nodes with a single input/output respectively. All settings for a particular interface socket can be either displayed on the node itself or in the extended setting in the side bar (active node panel). This includes the socket name, data type, subtype (currently not directly editable), default values and optional custom limits. This has a couple of advantages:
  • It reduces clutter in the layout. Interface nodes can be placed by the user just like any other node, thereby cleaning up the layout and making it much easier to understand. Inputs/outputs can be closer to the internal nodes that make use of them.
  • No more automatic unintended movement when the bounding box changes. Less problems with unintentional inserting of nodes in links.
  • Less space wasted on interface settings. Once the group socket has been set up properly the node can be collapsed and only takes a small amount of space.
Current way of linking sockets to the input/output columns
Proposed input/output interface nodes
Some questions:
  • How to set up the order of inputs/outputs?
    The column stacks make this quite intuitive, so i suggest to keep socket display there, but just display names. Changing the ordering there should use drag&drop instead of buttons (much easier also saves space).
  • Only one node for each input/output, having multiple nodes for the same socket would be too confusing. Using the same input in different places can still lead to long links, but it”s much more controllable then and is at least not worse than the current system.
  • It would be nice to still have some visual indication of which tree socket in the column associates to which internal node. This is not as important as it may seem at first, since there is no real functional connection between the order of sockets in the columns and their nodes. However, some sort of highlighting indicator when selecting the node or the column item would make it easier to recognize them quickly.
Generating top-level interfaces from node trees
This feature is not actually a cure for an urgent problem, but will help increase usability for node assets. The idea is that any top-level node tree used as part of a material or texture or (later) modifiers and particles would be more usable with a compact interface (in buttons window) with just the important changeable settings.
As an example, consider a node tree setup for Cycles. Every material in Cycles consists of nodes, there is no hardcoded, non-node material system any longer – the node tree essentially is the material. Now, when using an existing material node tree there are usually a plethora of possible input parameters to consider: any unconnected node input in the tree must be considered by the user. There has been some effort by Brecht to implement a more “classic” list-style view of the nodes in the material buttons panel, but imho this is not of much help for large and complex node trees.
What i want to propose is to use the existing options for group node sockets as a means of creating an “outer” interface for such node trees. Basically what we are doing in node groups is defining an interface out of all the possible parameters used by internal nodes. Until now the only place where this interface is presented to the user are the group node instances: all exposed inputs and outputs of the group tree are translated to simple sockets on the group nodes linking to it. It would be quite simple to use the same system for displaying such an interface as buttons in the button space. Not only does this reduce the vast amount of possible input parameters to a sensible necessary subset (which can be extended when needed), but it also allows us to use meaningful names for parameters.
The snow shader example with current node tree list view
With just a few input nodes the interface can be reduced to meaningful parameters
UPDATE
After implementing the first two of the features mentioned above (interface proxy nodes and browser-like tree editing), i”ve made a little video tour to show them in action:
Node Groups Editor Tour
Declarative Systems in Geometry Nodes
Winter of Quality 2025
Layered Animation Workshop 2024
The Future of Overrides
31 comments
  1. One good example of re-using Compositor nodes: using Edge Nodes to control Toon Line renders:
    http://blendernpr.org/bnpr-exclusive-edge-nodes-part-3/
    It took me a while to discover that I couldn’t append/link nodes until I had put them in a group and saved the .blend.
    For these (wonderful) Edge Nodes, that means I had to ungroup some of them, after appending.
  2. Compers absolutely do reuse nodegroups. The intelligent approach to nodes in Blender should be taken with an eye on The Foundry’s Nuke and/or Houdini where the big strength is just this, the reusable node groups. There is a reason these two applications are both the go-to-applications for complex workflows in the really high-end productions.
  3. YES LUKAS !! For this proposal, it’s more logic,coherent and understandable !
    (http://wiki.blender.org/index.php/File:Group_node_interface_006.png)
    Q_00 : (= it’s a question 00)
    Q_01 : It’s possible to make “vertical guides” with auto snapping to align all theses numerous nodes and nodes groups for a better visual organization… ?
    (and if you want horizontal too ?? i think horizontal-guides are less needful…?)
    (Like graphics-software, when we can see the rules, we can drag guides (vertical or horizontal)
    Q_02 : And if we move one guide, all nodes and nodes-groups (aligned on this guide) move with it => to stay always aligned… ??
    Q_03 : One button to display and hide theses guides and snapping… ?
    And why not, after when we open a node-group, it’s stay aligned on the right of the the guide
    THANKS for all of you !! ;-)
    ps: In the futur, you think that the logic editor will be like the node editor… ? i love your visual interface !!
    • Currently you could use the usual scale operator (s key) to align nodes on x or y. This is not a persistent alignment however.
      Beside that you could use the “frame” node to group such nodes together, though it is still quite experimental and will need improvement (see proposal above).
      I don’t have any plans to add such dedicated tools (rulers/guides) at this point. It would need a good solid design first, not sure how this would fit in the rest of the node editing functionality. The ideas sound a bit too vague at the moment.
      The game logic editor might very well use nodes in the future too, but i don’t intend to implement this myself (generally i’m not very interested in BGE stuff ;) ).
      IMHO a much more important application of nodes would be for reimplementing the old OOPS schematic ( http://wiki.blender.org/index.php/Doc:2.4/Reference/Windows/Outliner ). This would be a nice way to tie together future node systems for modifiers, particles and other potential object/scene components.
  4. Isn’t the name “frame node” a bit confusing?
    Some users might think “frame” relates to the (time) frames in the time line and take the node for something time related.
    (Although I admit once you add the node it doesn’t look like it has time functionality…)
    • Sorry, i don’t get what you mean :) Can you describe it in words?
    • Ok, i guess what you mean is: Instead of adding an extra node to expose an input, tag the input in a way that makes it appear as a group socket?
      I have considered this approach, and i realize it looks a bit simpler at first, but this is why i think using proxy nodes is better in the long run:
      1) You can only use such an input for a single socket. With proxy nodes you can have a group node input that is linked to more than one internal node! It might be possible to do this with a kind of “Pass” node that simply passes a value unmodified from input to output (expose the Pass node input, connect the output to different nodes), but then again you have basically a more complicated proxy node.
      2) When you remove the internal node you inevitably lose the output, including any external nodes connected to the group! With proxy nodes this cannot happen, you can simply reconnect the proxy internally.
      3) Proxy nodes offer a convenient way to display all the details about the type of the interface socket (name, type, value range, etc.). With directly exposed inputs you are effectively limited to the hardcoded type of the internal socket.
      Exposing a socket is really simple and fast too, i don’t think it adds too much of a burden on the artist: press shift, click socket, drag and release, done.
  5. And change yellow groups color to green color… ???
    • Maybe, but there’s hardly any unique color left to use only for proxy nodes (Cycles shader sockets are green already). Can be decided on when it’s time for trunk merge.
  6. Goods ideas, but in image-proposal : “Proposed input/output interface nodes” ,
    can you change too, the color of the vertical little circles on the left : Height, Blend, Start, Noise and Noise Scal(e), to have a better first idea of all groups…
    Thanks to all !!
  7. Good thinking overall. I just want to add some questions.
    How should input sockets be created? Currently you make a connection to the left column. If the same method would be used but when connected it instead creates an input node, it would seem weird (imho) that the connection you just made gets “disconnected” and instead a node pops up.
    Also, I think it would help if there is some visual queue to distinguish input nodes from output nodes. In your mock-up, they’re distinguishable from normal nodes in that they’re yellow headers, but there is no way to distinguish input nodes from output nodes other than which side the socket is on. I’d suggest input nodes and output nodes have different colors on their headers.
    Just my 2c.
    • I fail to understand the problem with inputs. It works by dragging onto empty area with SHIFT key pressed (keymapped), then release to create a proxy input node. Nothing getting disconnected really, except if you replace an existing connection (but that’s how it works in Blender nodes in general).
      Different colors for inputs and outputs are possible, but would like to
      wait and see if it’s necessary. Too many different colors just obscure things and in my personal experience it’s not hard to distinguish proxy types.
  8. Hey Lukas.
    Today my class was introduced to Grasshopper for Rhino.
    Nodesystem for advanced geometry making but the simple node components are really simple. Points and lines from inputs etc.
    We only have the trial of Rhino for a week now but Grasshopper it is incredibly well done.
    It also seems like it is open source. (or i might have missed something)
    Anyway are you familiar with it?
    Best luck.
  9. One thought I had for node groups was to allow a note to the group – maybe linked to a text editor item or just part off the group data – to allow a short explanation to be contained with it, making it easier to share node groups through a project and help to remember why they made the group etc.
  10. A great analysis, with great ideas.I have nothing to add, just wishing the implementation goes smoothly!
  11. Why not replacing all unary/binary mathematical nodes (+,-, * …) with a node where the user can enter natural formulas ?
    A example : “a*sin(x) + cos(y)” as text in a single node would replace 4 unary/binary nodes
    This could avoid to code a complex hierarchical node system
    • Well, maybe such nodes could be useful, but that is a different topic. Node groups/assets/frames have a lot of other purposes than saving space and mathematical expressions are just a small subset of node types.
      Beside that, what are x, y and a in your equation? These inputs must also be defined somehow. Drivers are doing it this way, with local variables defined from RNA properties. The reason we use nodes after all is visual immediacy, which drivers lack inherently.
      • a, x, and y are constants or variables.
        The node could work this way:
        – When user enters a forula, a parser cherchs its correctness
        – if it detects variables, propose to edit the value directly in the node (as a constant), or as a node input
        this could make the use of nodes more readeable (ihmo)
        • I like the math nodes the way they are, but I sure wouldn’t mind having an extra node called, say, Expression, which obviously would have a field in it where you could enter an expression into it, that would be pretty sweet…
          • Yeah, in VVVV there’s also a node called “expr” additionally to the unary ones. The inputs it gets can be used inside the formula as a, b, c and so on.
            Generally I think it’s best to analyze the advantages of other Visual Programming Interfaces like VVVV, MaxMSP, TouchDesigner…
  12. I have read this article carefully, because I am just writing the chapter of my book that introduces Node Editor and Cycles. (I would like to know, what will be changed and have to be rewritten). The ideas, presented here, sound great.
    I just think about the change of the group input/output socket presentation: current solution (grab a scocket and drop on the left or right) is more intuitive, than creation a special input node. On the other hand, I completly agree that current solution creates too much extra “wiring” inside a group definition.
    I would propose a compromise: just add to the proposed group input / output sockets solution following functionality:
    – when you grab a internal node socket, and drop it on the group input frame column, it creates an input node and places it in the nearby.
    This way it will be easier to explain the idea of input/output nodes to a new user. I think that this kind of intelligent drag/drop functionality will make this solution easier to use also for the other, more advanced users.
    • It’s hard to say how this will work in all details, which is unfortunate for book authors of course, but there’s nothing i can do about that.
      There will definitely be a quick way to expose sockets to the interface, like drag&drop with a key pressed or so. The group border can be quite far away in large groups, so the current way of dragging out of the group can be annoying. Also if node assets are edited as individual node trees there will be no such border ;)
      It depends on usability testing and some creative thinking how this turns out in the end.
  13. a very detailed writeup, thank you Lukas. Nearly every feature/change you’ve mentioned would bring some modern dynamism to Blender’s node functionality. Anything that users in more advanced compositing interfaces, along with a bit of how Houdini handles nodes, is a good thing in my book ;-)
  14. I’d love to see the bounding box (and columns) removed in favour of VSE style groups that replace the editor/percent-node-tree.
  15. This is a thorough analysis with very good points.
    I really like your ideas of improving the group node and with the asset manager this could be very useful for sharing (which blender is all about).
    Just from skimming the text, the group node and the frame node kind of share some functionality. Especially if you take the group node as a solution to the collapsible frame node socket problem.
    Would it be a solution if that they were the same?
    The group node got the features of the frame node and the frame node no longer needed?
    Best luck and thanks.
    • IMO the current groups already try to combine both of these two ideas, but fail to do so:
      a) Actual *grouping* of nodes in the UI: place them next to each other and treat as a single block.
      b) Make reusable assets with meaningful interfaces.
      Doing both with the same node type requires too many compromises so neither function works well. Grouping with otherwise independent node trees is complicated code-wise and lacks many features, such as connecting between different groups. OTOH treating groups *as if* they were local to a specific node tree does not work with multiple open groups and deeper nesting.
      Splitting this up into two different types of nodes will allow us to focus on each specific task. “Frame” nodes can be used to organize nodes nicely in a tree, while node tree assets can have customized interfaces and be linked in various places. You can also combine them freely, place frames in an asset tree and vice versa.
In order to prevent spam, comments are closed 7 days after the post is published.
Feel free to continue the conversation on the forums.
